Code 23, H22 with P13 ECU
    I was working on a H22 in a CB7 with a P13 ECU that was throwing a code 23 for a knock sensor. Replaced the knock sensor with one from Honda and checked continuity from the plug of the knock sensor to inside the ECU and it had continuity. Opened up the ECU and nothing looked burnt and all of the solder connections looked good. Would it be best to get a chipped ECU with a street tune on it and eliminate the knock sensor or try another P13 ECU?
    Best to get it working properly before you go eliminating anything.... though it sounds like everything should be working properly. Do you know anyone locally that has a known-working P13 you could try, so you don't have to throw money away if the ECU isn't the problem? That would be the first thing I would try to do if I was in your situation.
      alright, there are only 2 of us h22 accord guys here in gainesville so finding another one may have to be a junkyard find. thanks for the help
        I have read a little on knock sensor problems with h22. Something about using insulated wires so the the ecu doesn't get a false reading while driving.
        Steve
          The wires for the knock sensor in the OEM harness are shielded. But I used regular wire when I did my swap and have never had an issue. I've got 70,000 miles and 6 years on the swap now.
          My swap thread
          Main relay proplems?--DIY
