I'm not sure if it's my clutch or not, (it needs replaced) but when I have the clutch in the tac shows the RPMs dropping to zero and the motor sputters. It did it earlier when I was messing around and just barely revving to maybe 1k RPMs and it would drop to nothing and would sputter, and did it yesterday when driving as I slowed down and put the clutch in to keep the motor from dying when braking. Any ideas?
Tachometer/Clutch Issues?
Alright lol I just got the carOriginally posted by cloudasc View PostSounds like your throw-out bearing is done. That is why the car tries to stall out when you press in the clutch. I had the same issue with my old Rx7.
One driving behavior that can cause a throw-out bearing to go out prematurely is keeping the clutch depressed when at stop lights.
Okay, so she stalled on me while I had the clutch in and was slowing down at a stop light. Pushed the CB into a parking lot and messed with a relay dangling down by my foot from below the steering column (I think the car has electrical issues, the ABS light is on and it seems to work. So is the "Brake Lamp" light after using my brakes and they still work fine. Any ideas?
