I've been looking around and can't seem to find anything. I know our cbs are supposed to have a 17 gallon tank. When I went to fill up last week it only let me put in 11 gallons. Now there was some gas in it but not 6 gallons. So I'm wondering if it actually holds 17 or if it's just a myth. Going on a road trip from st Paul Minnesota to Madison wisconsin. Should be fun. Also Go Ducks!!!!
Gas tank size?
What makes you think there wasn't 6 gallons in there? Just because the gauge says 1/8th full doesn't mean you're almost out. These are 20+ year old cars. Sensors, gauges, and other stuff start to break and malfunction. Gas tanks don't change size. You should always trip your odometer after each fill up. I like to fill up right around 300 miles on a tank. I know I can go more but it's just a personal preference. Odds are your gauge isn't 100%.
I've put as much as 15.5 gallons in my car, I avg around 14.5 though.Originally posted by ChandlerFihn View PostI've been looking around and can't seem to find anything. I know our cbs are supposed to have a 17 gallon tank. When I went to fill up last week it only let me put in 11 gallons. Now there was some gas in it but not 6 gallons. So I'm wondering if it actually holds 17 or if it's just a myth. Going on a road trip from st Paul Minnesota to Madison wisconsin. Should be fun. Also Go Ducks!!!!
Humor me....are we supposed to know about "The Ducks"?
'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
I guess I'm not positive but I'm at about 400 miles on this tank and the needle is right above the e. But I only put 11 gallons in. And the gauge was at the same point. So I'm lost.Originally posted by BurtonRiderT6 View PostWhat makes you think there wasn't 6 gallons in there? Just because the gauge says 1/8th full doesn't mean you're almost out. These are 20+ year old cars. Sensors, gauges, and other stuff start to break and malfunction. Gas tanks don't change size. You should always trip your odometer after each fill up. I like to fill up right around 300 miles on a tank. I know I can go more but it's just a personal preference. Odds are your gauge isn't 100%.
It is a 17 gallon tank. Ive gone as far as 490 miles to my full tank before my gas light came on and i had to fill up. My light came on right at the E and i still drove another 30 miles to where i was going..your gauge is off and most likely because it is a 20 year old car
Rush
Originally posted by DarkcloudBought 3 things, 1 that goes boom,1 that shades and 1 to go fasrer
Originally posted by bmxicansdso you got a boombox, sunglasses and rosettta stone?
17.1 gallons
I can only hold about 11 as well.. hmm.Originally posted by ChandlerFihn View PostI've been looking around and can't seem to find anything. I know our cbs are supposed to have a 17 gallon tank. When I went to fill up last week it only let me put in 11 gallons. Now there was some gas in it but not 6 gallons. So I'm wondering if it actually holds 17 or if it's just a myth. Going on a road trip from st Paul Minnesota to Madison wisconsin. Should be fun. Also Go Ducks!!!!Originally posted by Quashishhahaha
noobs be like where to be buying hella flush yo?
Correct.Originally posted by Losiracer2 View Post17.1 gallons
In all likelihood you will not be able to use the full capacity of the tank, the last gallon or so ends up being a 'puddle' in the tank. I've filled up 16.1 gallons before, right after it had its first 'stutter' from starvation. My gas light comes on at 13.5 to the 14 gallon mark.
Also if your getting that kind of mileage on your car for such little gas usage, then I have to ask, what size tires are you running on the front? The wrong sized tire will cause a speedometer to read high, can make your MPG look better than it is, and cause your odometer to record extra miles that are not really being put on the car.
when i first got my CB i wasnt familiar with "how long i can drive with the gas light on" luckily when my car stalled out i was able to make it to a gas station. it took a little under 16 gallons (16.97...), but every time i fill up (when gas light turns on) its roughly between 13.2-14.6 gallons (which is between 350ish-370ish at every fill up).FRIENDS
DONT LET
FRIENDS
ROLL ON
ROTA'S
I dont think my gauage is wrong and i assume that there was already certain amount of gas in it. i did get 400 so it was obviously full.Originally posted by cloudasc View PostCorrect.
The ducks comment was pointed towards college football. Im from oregon and the best college football team in the country is located there.
And i am runnning 215/45/17 as tires but i use a gps to track my mileage.
