it can be done, it will be the same as a normal k-series accord swap other than you will need an accord 5spd, tsx 6spd or jdm euroR. just to clarify, all k-series trans. the intake manifold must be swapped for a non drive by wire unit and you will need a custom header do to the single exhaust port of the new k-series. if it were me, providing you actually have this engine in your possession, i would sell this and buy a full k24a2 swap or do a k24a4 and throw in some rods and pistons with a k20a2/z3 head swap. it'll go much smoother. the k24z7 will work it just requires alot of unnecessary work for a k-swap. ive seen few cb7s on here with k-swaps. just search, im sure you can get help.
2012 si motor swap?
I guess I'll give you a freebie on that one. I edited for you and the future people who may look at it.Originally posted by Accord problems View Postyes i did thank you very much . the only thing it even said was The Honda B-series was replaced by the K-series in Civic and Integra applications. and you i both know that the wikki can't be trusted .
But you should have seen that the B-Series discontinued in 2001, so what did you expect came in CR-Vs from 2002 to the present?
'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
could have been any thing like the f20c.Originally posted by Joey GT-R View PostI guess I'll give you a freebie on that one. I edited for you and the future people who may look at it.
Car safety checks
Fluid Capacities
K24Z7 mite be the worst K series motor of all time
Youd seriously do better getting a K24A1
Swapping into a CB isn't worth it though... at this point it would be cheaper to get a 7th gen Accord Coupe
You should start a new thread if you're going to revert to a totally different topic.Originally posted by barefoot2012 View Postalright my car has developed a problem, it broke a cv axle earlier and it seems something is wrong with the transmission, it will not move in any gear, but if it is in neutral and I release the clutch it acts like its in gear and it will drive forward.
If you snapped an axle you could have damaged the clutch and/or the transmission. I snapped an axle a year ago, and damaged both.'94 JDM H22A: 178whp 146wtq
