I have a 93 accord ex that was originally an automatic. I bought the car as it's sitting now. It has an F23 engine I've been told was from an 02, but I don't know which version. (I can get more specifics, but I don't know where to look. :/ ) and I have an h22 manual transmission.
I've been hitting limp mode with CEL readings 12 and 13 (EGR valve and BARO).
I was told that the BARO sensor is in the ECU and it would just need to be replaced and the ECU itself is most likely the reason why I'm getting limp mode.
I want to purchase a replacement but I want to make sure I'm purchasing the right one.
The ECU that's currently in it is from a 95 and reads 37820 P0A A51. When I look it up it says that it's meant for an automatic. As I'm not well versed in the Accord my main questions are should I just purchase the same model ECU, and if not how much wiring will I need to change, if any and which one would be the best one for my particular car?
Thank you in advance for your time and help.
