I don't know what it can be, but my battery light lights up a little when I am in the 4k range.. Hopefully its my alternator, but any help is appreciated
battery light dims on acceleration
This happened to me recently exact same thing and it was the voltage regulator failing. NO MATTER WHAT YOU DO. DO NOT BUY AUTOZONE ALTERNATER as I had to repeat my work four times until getting a good one I cannot stress that enough to avoid that place I find that Pep boys is more reliable on alternators along with advance auto. You might want to make sure the voltage isn't getting real high when mine failed it would ether get really low voltage or high like 16-18 volt high and I'm sure it could damage electrical components if left running be sure to look for discounts if you buy from those places use retail me not.
All of their alternators are usually refurbished.. So I'll look into buying a brand new one next pay checkOriginally posted by kevinhughes13 View PostThis happened to me recently exact same thing and it was the voltage regulator failing. NO MATTER WHAT YOU DO. DO NOT BUY AUTOZONE ALTERNATER as I had to repeat my work four times until getting a good one I cannot stress that enough to avoid that place I find that Pep boys is more reliable on alternators along with advance auto. You might want to make sure the voltage isn't getting real high when mine failed it would ether get really low voltage or high like 16-18 volt high and I'm sure it could damage electrical components if left running be sure to look for discounts if you buy from those places use retail me not.
For $160 you can get an alterstart high output alternator. 135, 160amp
As long as you don't have a high idle amperage need.
I've had 2 and they are good.
http://https://secure.mysuperpagesho...ator-160-amps/
Steve
