throttle body cable
    Yeah rookie mistake here.Lol
    I'll find a way. For now I'll be using f22 tb.
      Originally posted by K0548035 View Post
      My f tb on the back side is 5.5cm and my h23 plenum is 6.2cm (I like to measure everything). Will it disturb anything by having 5.5 over 6.2?
      itll cause some turbulence, if i was doing it tho, id get one of those cheap aluminum throttle body spacers and bore it out to make the transition smooth from the tb to the plenum.
        For the price that you paid, you could have got an Omni Power TB in the size that you need/want.
          Aw.....damn
            here what I am going to get.
            MAP sensor adapter
            http://m.ebay.com/itm?itemId=161710851537
            TB
            http://www.ebay.com/itm/301166874213
            lemme know if something is not right.
            Thank you for all of your help.
              damn youd pay 30 bucks for that turd looking adapter? and still have to get a npt brass barb it looks like. Ive seen the adapter with the barb already part of the piece somewhere. heres a block off plate for 12 obo. why not even snag a map sensor the plug with a bit of wire and the little oring from the j/y and wire it in, its really easy.
              http://www.ebay.com/itm/220-Racing-M...0c436e&vxp=mtr
                I don't get what you mean with map wiring thing.
                and my map sensor is a black box next to the battery, above the small intake. Tube(scoop?)
                  If your bay is still stock. Your manifold air pressure (MAP) sensor should be located in a black box mounted to the firewall above/behind the intake manifold. The black box should have a couple vacuum hoses and sensors inside it.
                  The black box on the intake tube is an air resonator solenoid.... it's there for noise reduction!
                  Unless you have altered your bay, then you would have to post pictures for us to see what has been changed.
                  MR Thread
                  GhostAccord 2.4L Blog
                  by Chappy, on Flickr
                    I will take picture in a moment.
                    Also what the red hose for? That one suppose plug in above tb?
                      If I'm not mistaken that is the vacuum for the MAP sensor.
                      MR Thread
                        I'll just take pictures lol
                          MR Thread
                            thanks fr the picture... that helps a lot!
                            but it didnt show the red hose route..
                            here the piture
                            and this is not importance?
                              the red hose its for the charcoal canister fumes any vac source will work. yes you have a map sensor in the black box on the firewall that gets its vacuum from a hose. i meant put a map sensor where you have tape on the throttle body.
                                Again I appreciate your time and patient in helping me. I bypass some open vacuum hose. I'll post up a pic in a min.
                                For the kickdown... Is there a modficaton way or I have to use oem style?
