Hello fellow cb7 owners!
I just finished swapping f22a6 motor on my 92 ex sedan. Everything starts up, runs fine everything is good.
My question is how can you tell a worn out shifter cable?During the time of swap I forgot to detached the shifter cable while I took the motor and transmission as a whole unit so it stretched the cable.
So I bought a used one at the junkyard and installed it. Problem is I can't drive nor go in reverse. Car does not move at all. Yes I have a TCU code #2 , I'll have to pick one of the "2-Lock-up solenoid 'B' circuit open or shorted"up sometime this weekend or the follow week since the junkyard is 70 miles away from me. I did all the test and no clicks at all. So figure I'll get one.
Sorry back on topic, when the car is running I step on the brake pedal i then press the tab with my right thumb to go in Reverse. From then on I can slide the shifter from R, N,D4,D3 and back with ease. I'm assuming the shifter cable is defective. Should I find another one at the yard or buy a brand new one. The one i got now I don't see nothing wrong with it. Will a shifter cable from CD5 work on cb7. Found one from a local craigslist since its near my house.
Any idea? Sorry guys I'm kinda bad at explaining things in writing.
