oil problems
    oil problems
    ok so i changed my oil 2 days ago while i was changing it i noticed its way more than 4 quarts it turned out to be 6 so i filled her up with 4 an took a test drive she died out on me while i was at a stop sign the oil light an battery light came on idk whats wrong an help would be great
    The battery and oil light should always be on when the engine isn't running and the key in the on position. I believe your observations are a coincidence.
    Did it start back up?
    Did it die again?
    Notice any change in performance?
    YouTube Clicky!!
      the car will start back up but will die at any stop light an performance wise nothing my idle is smooth an constant until i come to a stop itll shake hard then die
        changing oil shouldnt do that, did you bump anything while under the hood? sounds to me like you need your TPS calibrated..or maybe you have a vac leak. good luck
          theres no vac leak i checked an i havent done anything but change the valve cover gaskets
            Is your oil level at the proper level currently?
              yea its at the full line on the dipstick
                If it idles normally, but dies on the transition back to an idle, than you most likely have a problem with the idle control system somewhere. You might want to check things like your mechanical idle (the idle screw) and the various sensors. Small vacuum leaks might cause that too if they are in certain areas. You may also want to check your ECU for fault codes. It could be a problem with the IAC valve, or fast idle valve, but those will usually throw a code, which is why I suspect someone may have jacked with the idle screw at some point.
