ok so im having troubling finding reverse an D4 in my 92 ex i can put the car in reverse an it rolls forward like its in neutral same goes for D4 if i play around with it will fall in gear an it just started doing this saturday
automatic trans cant find gear
The tcu store's it sepret from the ecu . it will sport light or the d4 .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
