Lower Timing Cover Remove
    Ok guys, please tell this newb the trick to get the lower timing cover out of the engine compartment.
    engine mount is off and timing cover loose near bottom of engine, just can't figure out the puzzle.
    Thanks
    Have you taken the crank pulley off yet? If not, it is required to get the lower cover off.
    MRT: 1993 Honda Accord SE Coupe (Lola)
      Keep struggling with it. It will sense your frustration and eventually release itself.
      Also, make sure you are pulling from the bottom.
      YouTube Clicky!!
        wow, you guys suck.
        Pulled A/C compressor off bracket and it rotated CW and came up out the front. Already had PS and Alt off.
          Yes, insult the people that are trying to help you. That'll get you what you want.
          Good luck, homie.
            Good luck, homie.
            A sarcastic you guys suck is not quite an insult and those 2 weren't helping....
            Thanks for stopping by.
              Hahahahha
              sold! But here's my build thread for those interested.
              http://www.cb7tuner.com/vbb/showthread.php?t=206864
                Both of them offered useful information, actually. I'm pretty sure nobody is going to waste their time from here on out, though. Nobody wants to be told that they suck... which is a shame, because the two people you just insulted are very knowledgeable, and would have been able to help with your problem.
                  Originally posted by RedTRex View Post
                  wow, you guys suck.
                  The advice given was spot on - you basically have to yank on the thing and move it around until it will free itself and slide out the bottom.
                  1992 EX, 306,000 miles - Track toy - M2S4, H23A1, ST rear swaybar, Wagon brakes, GC coil sleeves, KYB AGX dampers, Stoptech pads, Toyo Proxes R1R, 2.25" exhaust
                  Stock F22A6
                  VIR, 5/22/2016: https://youtu.be/eR5-ylSPsxk
                  H23A1 powered
                  NCCAR, 9/4/2016: https://www.youtube.com/watch?v=TI5WpxGrEpE
                  CMP, 10/16/2016: https://youtu.be/DOqoe5f-GLY
                    I've never had to remove any of the brackets from the front of the engine to get this timing cover to come out. Usually it's mess around with it for a few minutes until it rotates correctly and then it slides out the bottom fairly easily. I can't remember how to it has to be rotated to come out, so I can't comment on that but it seems like common sense. Not sure why the OP had so many issues...
                      x2
                      I'm not sure where he was getting hung up at. (See what I did there?)
                      But hey, whatever works. Glad we could be of assistance.
                      YouTube Clicky!!
                        never thought to remove the AC bracket, i usually just wrestle it out, knocking the gasket loose in the process (sucks). Then wrestle it back in, and attempt to re-seat the gasket while it's already in place (really sucks). I will need to try your way next time.
                          OP, may want to invest in a manual. They come in handy, hope this helps and I don't suck as well.
                            Okay, I'll eat some crow...... You guys rock and I appreciate the help.
                            I can see how the yanking will eventually work. But how to yank it back in without tearing up the edge seals?
                            I do have a manual and it just says "remove lower timing cover."
                            It came out easy after removing the 4 compressor bolts and moving the compressor out of the way.
                              Both CB7's I've had were missing the seal, but yes, it would be nearly impossible to reinstall it with the seal unless it was RTV'd together.
                              Stock F22A6
                              H23A1 powered
