Hi im having a problem with my passenger seatbelt. Sometimes it works sometimes it dont. It usually gets stuck in the door closes position, now i know its better to be stuck in this posotion then rhe other but it just gets on my nerves. Sometimes i can wiggle it and it works, but lately nothing i do moves it. I know this has probavly been explained a lot but my phone qont let me use the sites search engine to search it. Itshows up but in the middle if typing it dissappears. Thanks for any and all help
automatic seatbelt problem
does you're seat belt warning sing keep on ? you're track's probly need cleaning and lube . if not it may a bad sensor .this was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
