Hey guys I was wondering if anyone knew what could be wrong or is going on I have a 93 accord 2 door with a f22 non vtec.the car won't go in neutral I can find 1st 2nd 3rd and 4th reverse. .any clues what this could be please help.
Transmission problems
You should probably specify whether it's automatic or manual.sold! But here's my build thread for those interested.
http://www.cb7tuner.com/vbb/showthread.php?t=206864
Ive never heard of it not going in neutral. If you can transfer from gear to gear then you are moving through neutral. Not to question our driving ability but you do know when your in neutral correct? If the shifter can be sweep fully from the driver side to the passenger side. Should be able to jiggle it and the engine wont bog down when you let of the clutch.~Nick~
You go into neutral to get into each gear. If you're saying you can't get the car out of gear when its on then your clutch is gone, but honestly I'm confused to what you're even saying.sold! But here's my build thread for those interested.
Even if the clutch was gone he should be able to pull the trans out of gear, he just wouldn't be able to put it in gear.Originally posted by lbus9168 View PostYou go into neutral to get into each gear. If you're saying you can't get the car out of gear when its on then your clutch is gone, but honestly I'm confused to what you're even saying.
OP, when you say your changing gears is the car running or is it off?? Can you give us a little bit more detail on whats going on? I too find your question/problem confusing.
Yeah, I know, I'm just trying to make a really wild guess.sold! But here's my build thread for those interested.
