Hi! I'm new to this site. I'm having trouble routing my vacuum lines. I did an engine swap on my 90 Honda Accord. It had an F22A4 with manual trans. A buddy of mine had a 94 Honda Accord with F22B2 (non-vtec). I replaced my engine with the 94 engine. I'm now having problems with routing my vaccuum lines and i don't see a map sensor plug to plug into the intake. I have lots of experience working on CB7 engine swaps/trans swap. CAN ANYONE HELP PLEASE?
1990 CB7 Engine Swap to F22B2
The MAP sensor on the F22B2 is mounted directly to the throttle body, it does not require a vacuum line.
If you are wanting to use the 1990 fire wall mounted black box MAP sensor. There is a vacuum tree on the drivers side of the upper intake plenum. It should have some available vacuum ports that you can run a hose from there to your firewall mounted MAP sensor.
Right on the end with the ECU Ground - G101 I'm pretty sure there are 5 vacuum ports on this tree.
