seems the weep hole or whatever is leaking on this new 40/40 valve i bought and installed..is this a common problem for these prop valves?
40/40 valve is leaking
also..new master cylinder, new hard lines, new hoses, as well as pads and calipers, the pedal seems really hard to the push..the only thing that isnt new is the booster.. btw this is a 92 ex coupe with rear disc and abs deleted, (hence why im using a 40/40 valve).. dont really want to take that damned prop valve back out...
I've never heard of anyone experiencing leaking issues. You're going to have to pull it. Clean the threads thoroughly on the lines and the valve. Inspect closely for damaged threads.
I'm not sure if thread locker is appropriate for brake components, but if it is, that might be a good idea (research and get more advice on that before doing it... I'm not sure enough of that to genuinely recommend it.)
Only time I heard of an issue is if you opened up and removed the da bracket from the assembly. I believe it was cpMike who pointed this out.~Nick~
