Ok So I did my searching and researching and couldn't find anything covering my questions so here goes..
1. Assuming you do not still have your stock radius arms for comparison (if they would even be helpful) how do you know exactly how long to set your (now) adjustable radius arms on a traction bar ( Innovative, Exp,etc..)?
2. It seems to me that having a solid connection between the hub and the cross member/traction bar would cause the wheels to toe in under compression or extension as the distance between the mounting points of the radius arms would naturally want to change.
