Ok, so just did a clutch on the coupe, but when i put her into gear, nothing happens. Even if i let off the clutch in gear, she idles like shes still in neutral. Could this be a bad slave? Fluid level was low when we checked it, filled it and still nothing.
Also, the odometer moves slowly on its own and the speedometer sits at 10 MPH at idle and when you rev her up, speed needle goes up too.
Any ideas? again
Edit: so i think the odometer issue is stemming from the speedo needle sitting at 10 MPH and would probably explain why she doesnt stall in gear with clutch out, but doesnt explain why it's happening.
Any ideas? again
