As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Power Steering Help!
    Originally posted by jross360 View Post
    from what ive been seeing, yes raf. I just removed all the oem hardlines a long time ago when i painted the bay, and didnt put them back in, so i cant tell whats going where..
    havent touched the car in a few days been super busy at work. Thinking about just going back to my looped setup with no ps. OR getting a line made at a hydraulic shop to connect the two?
    So assuming all you have is the rack, pump and reservoir, then yes you can loop B & D. But looping B & D implies you are not using the cb7 reservoir that has two inlet connectors.
    It's hard to say what cavities in the pump require fluid. IE - you wouldn't want to block D off if it was expecting fluid on one side of a pump.
      yes, all i have is the h23 bracket modified for pde h23a head, h23 pump, oem 92 ex rack and prelude high pressure line.
      edit: i am using the cb7 reservoir, just looping the two outputs and using the bottom nipple coming from the rack, and bigger outlet to pump
