So I'm getting weak spark at all four spark plugs. At one point it was getting good spark but wasn't firing because the camshafts where rotated 180° in the wrong direction. That's not the point i fucked up that part but i fixed it and now it's timed correctly.
I thought it was a battery issue at first because all of the attempts to start it. So i recharged the battery but still nothing. I hooked up my spark tester and the spark is very weak and orange in color.
I put a multimeter to the 7 pin pigtail for the distributor and checked the voltage. I can't remember the voltage when we cranked the engine but it seemed very low. I checked the resistance and that came out to be 8-9 ohms. To me that seems really high.
I don't really know where to check next. I looked a wiring diagram and from the dizzy to the next spot seems to be the main relay. The main relay is new so next would be ECU?
Here is more info about the car
New parts: plugs, wires, dizzy (TD-60u), main relay.
The harness is a 90 accord internal coil dizzy set up. The ecu is a JDM p13. The guy i bought it from says it's JDM.
I've heard internal coils suck. I do have a harness for a 93 ex but it was out of a auto and mine is a 5 speed. Could i still do a external conversion?
