So I recently purchased a p12 ECU and I went to remove the pt6 ECU from my Accord 91 Coupe and the bolt pattern on the ECU bracket is different I was wondering if I need to get a new ECU bracket from a Prelude or do I need to drill holes or put the ECU in without a bracket (I am new to Hondas and computerized cars in general) so if anyone has done the p12 swap some advice or pictures would be very helpful thank you very much!
P12 swap help
You can secure the P12 in any way you see fit, or don’t secure it at all. When I installed a different ECU, I just let it sit unattached. I suppose that could eventually lead to strain on the harness, though.
The easiest safe thing to do would probably be to hold the ECU to the plate with some zip ties.
Mine is in there with a combination of both. Some screws and some zipties. In your car it'll be hidden. No one will know. In my mine, who cares because, racecar.Originally posted by deevergote View PostYou can secure the P12 in any way you see fit, or don’t secure it at all. When I installed a different ECU, I just let it sit unattached. I suppose that could eventually lead to strain on the harness, though.
The easiest safe thing to do would probably be to hold the ECU to the plate with some zip ties.==========================
1991 Accord Lemons Race Car, "The Minnow" RIP
1993 Accord Lemons Race Car, "SpaceEx Starship"
Neuspeed Race Springs, Koni Sports, Acura CL Rear Sway Bar,
Adj Upper Control Arms -3.0deg front, -2.0 deg rear
M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake Fluid
When I had the P12 in my car, I just let it sit there attached to the harness on the floorboard. It literally never moved, and the tuned P06 I have in there now also has never moved, and I track/autocross the car.
I would not worry about it if I were you. There is just no need to try and drill new holes to fit the Prelude ECU bracket down there.
MRT
14.38 @ 98.66mph
The quest for 9s ceased, now the goal is a circuit track monster!
Current fastest Laguna Seca Lap: 1:52.346
