Hello. I read an informative post on here regarding the oil pan gasket on my 93 accord. There was a part number in the post, I assume this is correct. To change the oil pan gasket I will have to remove the exhaust pipe which are twin pipes from the manifold. I thought it was a one piece gasket with 3 bolt holes in it. It seems they may be 2 separate rings, is this correct? Lastly I am trying to get the small oil seal that goes inside the distributor, over the shaft. The number I have is BH3888E. I am in Australia and it looks like there is none available in the whole country. Thanks.
93 Accord CB7 oil pan and exhaust flange gaskets
Are you referring to the o ring on the outside that goes into the head? Any normal O ring should work as long as it’s the same size.
Here is the part number:
https://www.hondaautomotiveparts.com...VhbA%3D%3D
30110-PA1-732
They are all over eBay. Not sure if me sending it from the US would be cheap or not.~Nick~
Let me see if I have one laying around and if I do just pay shipping and I’ll send it your way.~Nick~
~Nick~
