Everytime I open the front windows and close them the glass gets out of place it leave a gap between the rubber strips so i usualy open the door to guide the window so it wont get out of place.
Window problem
That's only on the coupe. The sedan doesn't have that.Originally posted by Budmine did the same thing. there is a little bolt that fits through the top of the window and guides it along a little groove behind the glass. you have to take the glass and trim out to do it, but it's a fairly simple fix
I'm having the same problem in my sedan, but I haven't had the time or money to fix it as it's pretty much a minor inconvenience...Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
I agree. On my weather stripping i see like a tear half way up. And when roll up the window, the window goes straight through the tear.Originally posted by williamsvti actually have the same problem sometimes...i think its cause my weather stripping is old and is kind of displaced. i think the only real solution would be to get new weather stripping around the door, but thats kind of pricy and a bother..
my passenger window has that lil bolt hanging up the window. wont go completely down unless you hit it, lol. never even looked at it from outside but is there a way to tighten it up?Originally posted by Budmine did the same thing. there is a little bolt that fits through the top of the window and guides it along a little groove behind the glass. you have to take the glass and trim out to do it, but it's a fairly simple fix
i changed the whole regulator with motor thinking thats what had gone bad..and lo and behold, it made it worseOriginally posted by Gato-FFFirst, take off your door panel. Then loosen the track bolts, put up your window, once its up tighten the bolts down.
One other thing to look for is your window rubber strip, make sure its lubricated. Try using silicone spray to lube it.
...but i think it only made it worse cuz i had my dad help me and i kinda rushed in putting it all back together and mighta forgotten to tighten the bolts up all the way...
.hey shit happens..i was too excited cuz i wanted to get inside to make my extra set of headlights to blackhouse them lol...one day imma take it off again and try to adjust it from there..we'll see what happens..pe@ce love and chicken grease from the middle east...
o.k check it out .....my window was doing the samething so once i got tried of hold the window as i roll it up i went to the dealers and got a window plug it only costs $14 and its easy to install just remove the rubber that covers the screws roll the window down insert the plug threw the hole on the window and snap into the rubber lining than screw on very thight and WAALAA its fix it may shake here and there but at least its on
........i hope that helped out
EDIT: my bad thats if there is no plug now as for everything else....just replace it
