Originally posted by DjSpeedy
still drinking PS fluid like heck
Dry everything, fill up and see where its comin from. If you can see it on the floor you can see it in the undercarriage. Check the piping around your PS hoses on the rack. Look for where the leak is mainly at on the ground and look up from there. And as for removing PS if you remove it and its leaking from the rack you just decided to put money into buying a new one. WHenever removing PS you want a lubed rack thats looped not one thats dry and leaking.
I listed this in some other thread. Just take off the belt as everyone does and see if you like it or not. If you do just loop the rack and you should be fine.
Originally posted by Sector8CustomzI really don't want to thread jack but my p/s leaks and I topped off the tank once with penzoil power steering and not specific honda power steering am I screwed or can I still salvage my power steering parts?
and am still fine.
Not my fault my dick only fits magnums.
Why drink and drive when you can smoke and FLY?
go feel ur boots on your power steering rack, if it feels as if there is weight in it then thats where ur fluid is...the fluid has to go somewhere...
sometimes u can poke it with a toothpic and if fluid comes out then thats where ur leak is....What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
I have a similar issue with mine.....my leak is definately in the rack though......and it pours out like no tommorrow.....the car is not going anywhere till its replaced....just one of the many issues with my honda
i hear changing out a rack is a serious PITA.....anyone done this
Get your OEM Accord Arm Rest here!!!
1993 Honda accord coupe 5 spd.
2000 Ford F-150 supercab 2wd
1997 Sea-Doo GSX
