Help PLEASE! Emergency!
    O.k so i'm driving back from work today... As I'm accelerating from a stop sign from a dead stop, the car won't shift into 2nd gear (The rpm's just climb until redline and then it shifts) If I put it through the gears myself it almost always shifts (but I hafta do it myself) when I'm accelerating from a stop I have no power until the car starts picking up speed I'll shift from 1rst to 2nd (nothing will happen, but when I go from 2nd to 3rd it'll shift)
    When I stopped for gas I re-started the car and it gave me a nasty screeching grinding sound as it started and gave a small buck. (It never did this before)
    The car will not take off in first gear nor will it downshift to 1rst gear. Instead, I think it's taking off in 2nd, possible?
    Please tell me my tranny is not dead!!! and it's something else!
    Is that normal for all of that stuff to have started today and got progressively worse in the distance of 5km and only 20 minutes? It was running fine the whole rest of the day! WTF!!!???
    *Oh yeah, 92 accord ex 4door 2.2L automatic (if that helps)
    so when you try to go does it just rev and take a long time to go. if you punch the gas do you not get any power. do you drive the car hard. do you red line the car every time you drive it, if you do then you prob spun a bearing. do you hear any knocking noises from under the hood coming from the block. any knocking at all. let me know i think you migh have spun a bearing. wich in that case your gunna need a new engine.
      Well when was your last tranny flush and tranny filter replaced? Also is the tranny grinding? Is it engine? Starter? Ring gear on the torque converter may be bad but doubtful, torque converter could be goin, tranny could be goin, engine could be goin etc.! ALWAYS TRY THE EASIEST THINGS FIRST! Like a tranny service, at honda round here is only like 80bux so! Try that first!
      WaC!
        Ouch that does not sound good.
        I need to take mine to get flushed!
        Hope its not a big problem bro!
          i'm quite sure that's a bad torque converter
          [LEMNISCATE]
            Well that's all folks! Thanks for the help, the tranny is officialy dead!
            I need a car asap, so mine is for sale... highest bidder I guess.
              if you decide to part it out let me know!
              thats is EX and LX motor parts are interchangeble
                Part it out!
                  hey you could always put some lucas in it and sell it
                  turboed cb7 baby
