Clutch
    Clutch
    Ok my cousins engine blew and i was pulling everything apart and i unhooked the clutch line and i was goind to put it back on so i could move the car around.So i got everything back on and tight and hit the clutch pedal and there is no pressure i pumped the heck out of it and nothing.Any ideas
    Thanks
    you probably need to bleed the system and add fluid to the master cylinder.
    Members Ride
      agreed you will need to bleed the clutch system there should be a bleeder bolt on the front side of the tranny
        Yep. It's on the clutch slave cylinder.
          I added fluid and blead the clutch still nothing
            u done fucked up
              you will need to do this multible times untile you start feeling pressure ... just a little how to to make sure your doing it right pump the clutch 3 or 4 times then while holding it to the floor have someone open the bleeder valve then close it pump 3 or 4 times and hold while some one opens bleeder valve repeat until stiff if it doesnt get stiff you may have a leak somewhere in the system double check all lines
                yeah, you cant just do it once. you have to keep at it. pump pump pump pump pump!
