does the battery have to have a grounding wire?
where are the other ground wires?
is it necessary?
is it necessary?
). The starter worked when I pulled the H23 and I think it's still good- also because the dash lights didn't work right, they were all dim, check engine light was on, and the lights in the display were even on without the key in the ignition---wtf? That's cool if yours runs without it, but it's easy to make one and it can't be a bad idea...maybe your year/model has it in a different place? Hondaautomotive parts.com sells it new with the main ground (to engine block) cable assy.Illustration #14, BATTERY component -for 26.55, but you can look at the pic there and see what it looks like to make your own- it's just a piece of wire with some crimp-on ends. Seems important though
