Advice needed, possibly purchased the wrong H22
    Hi guys, I have a terribly embarrassing question today.
    I have a 92 LX coupe project car I've been working on for a few years now and I finally got my hands on an H22a4 out of a 2000 prelude base model to swap into my accord. now as I was rereading the steps to swap this into my accord more closely I noticed as most of you probably know that the guides and parts lists specifically ask for a OBD1 H22. A step I completely missed on my first few read throughs.
    So, sitting here sweating bullets, I'm asking is this engine now useless and am I totally screwed? or is there still a way to swap this without more money then both car and engine are worth.
    Fingers crossed here and thank you in advance for any help.
    -cheers
    Read this sticky and put your mind to rest.
    https://www.cb7tuner.com/vbb5/forum/...ior-to-posting
    You will have to get h22 obd1 injectors, dizzy and then use the accord harness and add 3 wires one for the vtec solenoid, one for the knock sensor, and one for the oil pressure switch on the vtec solenoid. You will also need the p13 ecu or a chipped ecu with vtec added. Look at phearable.net.
    Not knowing much about your car, I can’t really tailor the list of item you need to your setup.
    We are here to help. The Swap section literally covers most swaps in detail. Good luck.
    ~Nick~
      ahhh thank you so much, I'll dig through the swap forum some more and start scouting some parts.
        it's probably better you got a newer one anyway, with how old these things are getting.
          True, thanks for all the input. Been combing the swap forum for info.
            Bawitdaba da bang da bang diggy diggy diggy
            Shake the boogie said up jump the boogieBawitdaba da bang da bang diggy diggy diggy
