i’m getting ready to put a new fuel pump in and i see that there’s a hole at the bottom of the tank, it appears to be a fuel tank drain plug but i’m not sure was size it is i bought a 17mm and a 16mm and both didn’t fit i don’t want to keep buying the screw till i find the right size does anyone know what size plug it takes and where i could purchase one because i keep getting told no such plug exists when i could clearly see the plug on my tank…(91 accord ex 4dr)
fuel tank drain screw
Ya, don't think you can buy that plug. And it's a very loose 17mm. 16mm doesn't fit. But yep, that's the plug. Take it out and watch her make a mess
Obviously they come with new tanks though. or check junk yard if you need one. I'm sure other tanks probably use the same bolt (other accords).
https://torontohondaparts.com/PartsL...cal&illid=2616
