CB7 No Spark TCU Codes 3,7,8 Need Help
    Hi all. I need some help from you guys. About a month ago my CB7 with 75k miles started having trouble starting in cold weather, especially after refueling. It got to the point where I was stuck and unable to start it back up. I got it home with the help of some starting fluid where it remains dead in my driveway. Now im getting no spark but the motor still cranks. I replaced the battery for good measure and distributor because i had oil leaking from it but still no spark. My TCU is throwing codes 3,7,and 8. I suspect my old battery might have shorted when trying to jump it and maybe shorted some sensors in the car? Any help would be greatly appreciated. I also replaced the Main Fuel Relay after thinking it could be that but still nothing.
    TCU CODE LIST
    1-Lock-up solenoid 'A' circuit open or shorted.
    2-Lock-up solenoid 'B' circuit open or shorted.
    3-Throttle Position Sensor circuit open or shorted.
    4-Vehicle Speed Sensor open or shorted - No signal from speedometer.
    5-Shift Lever Position Switch circuit shorted.
    6-Shift Lever Position Switch circuit open.
    7-Shift Solenoid 'A' circuit open or shorted.
    8-Shift Solenoid 'B' circuit open or shorted.
    9-Counter shaft or transmission speed pulse generator open or shorted.
    10-Coolant Temperature Sensor open or shorted.
    11-Engine RPM (Ignition coil signal) open or shorted.
    12-(No code 12 used)
    13-Main shaft speed pulse generator open or shorted.
    14-Linear (line pressure control) solenoid open or shorted.
    15-Kick down switch circuit shorted.
    Besides the TCU issue it sounds like you have no fuel pressure. ie - fuel pump going bad. Ever check it?
      Thanks man, I think you're right i replaced the main fuel relay but it seems it might be the fuel pump giving me some problems. Any advice on tracing those TCU codes?
        Those TCU codes likely mean one of two things: you need a new TPS and new solenoids… or your TCU is bad.
        If you’re handy with a soldering iron, or know someone that is, pull the TCU. Crack it open and inspect for bad capacitors. They are known to fail with age. Reflow the solder joints. It can likely be saved.
        If you’re not good with that stuff, you can send it out to be repaired, or just buy a replacement.
