Hi everyone. I picked up a project 1992 EX that I would like to change the timing belt and the other seals while im in there. I suppose Camshaft, Crankshaft, Front balance shaft and oil pump/rear balance shaft seal. Is there any special procedure I need to know when replacing these seals? I've done a timing belt job on a 1999 acura CL 2.3 but the seals weren't replaced. I am getting some oil leaking down that area and figured ill replace those seals while im in there.
Is it a matter of loosening these sprackets/pully and replace the seals?
What are the torque spec for those Items?
Thank you for your help.
