eBay Motor Mount
    eBay Motor Mount
    Has anyone tried this?
    http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWA%3AVRI
    I'm going to change mine and this seems good...
    my member's ride thread
    its a bit pricey, but consider a new oem rear engine mount new will run you 150+
    so i thinks its a good deal. even if you could find them seperate cheaper. you still gotts pay shipping.
    and at least you wont have to worry about your engine moving around in you 13-16 year old engine bay..rubber doesnt last forever, and i bought a set like this when i put my new motor in
    good luck
    x
      man I paid 136$ for the front torque rod alone
      My Members Ride Page
        I have the full MT set, replaced them when I swapped to H23. They are absolutely identical to the stock ones except the rubber is a little stiffer. I would buy from these guys again and plan to eventually for my Prelude- they're really high quality. I asked if the Poly inserts would still work with these, and they said absolutely, but try them out first without...I decided to forget the urethane. They are solid but still comfortable and similar to stock. Poly will make the rest of your car vibrate, which is cool if that's what you want.
        PM me and get it done right!
          just make sure you let them know your trim also, along with the year and transmission type.
            Please forgive my poor English and bare knowing about car but I don't really
            understand what you mean...
            Thanks for all your sharing and I think I'll give it a try.
            My friend just spent about $400 for an OEM set at Honda
            and I can get the ebay set for a price at $200...
              i think he is referring to polyurethane, whether that be inserts or filling them with a liquid form to harden.
                It's cool, no problem. I was talking about polyurethane motor mount inserts that you can buy from Energy Suspension. They don't replace the other ones, they slide between the spaces to make a solid mount, but solid mounts transfer the vibration from the engine into the rest of the car, and some people don't like that.
