bogs, after a6 IM swap????
    I swap me a1 IM for a6 IM and ecu ,but it bogs when I'm taking off from a stop. I cleaned everything out before installing the new IM. any help would be great!
    motor f22a1 with
    IM & ecu f22a6
    header, CAI
    new plugs, cap, rotor,
    timing belt, plug wires
    thottlebody spacer
    auto trans
    next on the list
    get delta 260 cam and thottlebody bored, fuel pressure regulator
    then new trans and install t3 turbo with 450cc injectors
    I can't spell
    I swap mY a1 IM for a6 IM
      Originally posted by sr19
      I can't spell
      How do you have the secondary butterflies hooked up?
        to the ecu and the black box
        tps is ok .48v
          tps is ok .48v
          Did you use all of the original components from your A1 manifold? IACV, FIV, Fuel Injectors etc? Or did you use the ones that came with the new manifold if any?
            yes i used the a1 stuff
            timing check out ok
            it bogs at 1000 to 2200 rpms
              did you mess with your timing when swapping out the dizzy cap?
                never move it, same one
                  you install all the gaskets? i tried to reuse one b4 and had problems
                    yes,all new gaskets
                      is the throttle cable too tight causing the TB plate to be cracked open? are the butterflies shut at idle?
                      hold on to your butts
                        throttle cable has been checked it has some slack, but not to much
                        butterflies are shut at idle
                          just when for a drive and it bog again, but it sounded like it wanted to die so i rev-up and it was gone. hummmm
                            my throttle cable has a little slack also so that's probably normal.
                              i'd check the tune up items........make sure all wires are snapped tight, coil wire (if your's has it) is on tight (common for it to pop off), make sure the plugs are tight and not cracked, etc
