bogs, after a6 IM swap????
    cam timing is right on
    so its not off a tooth
      I will have to look the injector specs up again, but it seems to me that is just past the service limit.
      Unfortunately, the limits are just that. Like I said, I have seen them work intermittently or almost correctly right near the limit, but not usually passed it.
      I will look into and see if I can find any other information.
        book said
        lowest is 1.5
        and highest is 2.5
        so I need to put in some better ones, most likely
          Originally posted by sr19
          book said
          lowest is 1.5
          and highest is 2.5
          That is a distinct possibility.
          I was thinking about the post just above, and usually the heat/humidity shows as hesitation off the line, and now power anywhere.
            the heat didn't have to much to do with it
            it was 86 outside that day,plus it was at night(76-83)
              I was stating that more from the position that it probably had nothing to do with anything...
                well it not the valves they are ok, so I need to get better injectors and try them.
                but it's too damm hot it been 98+ for like 4 days not going to cool down till sunday so I'll try to get some then.
