Ok so either my cooling system is awesome or the temp gauge is faulty. Now when I turn on the car the needle moves but no matter how long I drive, how hot it is, or how hard I'm driving I've never seen the gauge go up at all. It seems to be always parallel with the ground, never seen it go above it at all. So what's the deal, is the cooling on our CB7's that good or is something fubar with that gauge?
Temp gauge not working?
dont run it hard till you fixs that i can't see a car with that good of a cooling system unless you have like a raceing radiator or somethinghttp://www.2kracing.com/index.php/cPath/4_60?osCsid=9dfebfe0d4f332b5c7b3498b65c09864
http://www.naganojapanese.com/jdm_f22b.htm
if the sensor or connection were bad, the gauge would read full-hot.
our cars regulate themselves at just under halfway up the gauge, like you said, parallel to the ground. if the car is basically stock, it shouldnt go above or below that.
sounds like your cooling system is working perfectly fine.
yeah I know this is an old thread but it still seems relevent. So should it move up the gauge if I run the car at 100+ for several minutes? I t never budged, and then one time I opened the hood and smelled hot coolant so that has me worrised too1992 Honda Accord DX
Coupe 5spd
2.2 liter I-4 (code: F22a1)
125hp @5200 rpm 137 lb/ft @4000 rpm
(\__/)
(O.o )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
to be honest, if ur car is stock and ur cooling system is great, then no matter how much u run that thing its still goin to be at that same level, unless ur on a highway and your doing over 100 for like 30mins"You don't have to be a Phi Beta Kappa to know not to strip-search a girl who is accused of stealing change,"
I did gagoogity that girl. I gashmoigitied her gaflavity with my googis. And I am sorry.
Have someone drive a car and stick your head out the window at say 40mph and then again at 70mph. The increase in speed also increase air/wind blowing at you. So even if your engine is working harder at say 100+mph there is also the air/wind factor to help cool it down.Originally posted by gofasteryeah I know this is an old thread but it still seems relevent. So should it move up the gauge if I run the car at 100+ for several minutes? I t never budged, and then one time I opened the hood and smelled hot coolant so that has me worrised too
that's true, I thought about that but at first it seemed like the extra work (engine is turning around 4k in 5th gear at 100 seemed to discredit that.1992 Honda Accord DX
Coupe 5spd
(\__/)
(O.o )
i think your temp gauge is fine mine is also parrallel to the ground. when i busted a hose that was old once the gauge went into the red then i immediatly replaced the hose and its all back to normal. i really think your fine. take it to a shop after running it for like 30 min and then have them check temp with temp gun they know where to point the laser temp gun and how hot the engine should be.1991 Honda Accord Lx 5spd manual
