cb7 tranny swap... auto to stick
    The auto-5spd swap isn't really all that difficult, the hardest parts in my experience are installing the pedals, shifter assembly and guage cluster...if you have ever dropped a tranny, then it's not going to be that hard. My first 5spd swap was in an EG civic, took 5 hours...but, I've been doing this for a while and can drop a trans and have a new one up in under 2 hours on a lift...3 hours on the floor with jack stands...so....ummm good luck?
    -Kyle
    SOHC Non-VTEC F-series for life
    "It is the fools prerogative to utter truths that no one else will speak."
    -Morpheus (The Sandman)
      thanx for all the help guys
      Upgrade your mind before you upgrade your car
      "So. Cal OUTLAWZ "
        GL!!!
        I wanted to do this to mine but its not worth it to me. Id rather keep it mostly stock and just fix it up and make it look really nice and buy a 5spd down the road and make that the beast
          Originally posted by Ralphie
          GL!!!
          well IMO i think its worth it cause doing the swap lets you get more familiar with your car and also more knowledge swapping out trannys and plus its cheaper than buying a new Cb7
          ________
          Lovely Wendie99
          CLICK ON SIG FOR MEMBERS RIDE
          "2SIIC"
          Authentic Jerseys for sale
          http://www.cb7tuner.com/vbb/showthread.php?t=188314
            can anyone give me an answer, how do you align the clutch? what do you align it against.....is it pretty simple once you are actually doing it? also the flywheel im gettin has no timing marks.....i have no idea what to do about that, since i dont have a stock 5spd flywheel to compare it to?
            1991 Accord LX Coupe - Boosted F22 - 5spd LSD - Shaved Bay - Work VSXX - Recaro SRD
            Member's Ride Page | Video of my CB7, Open Downpipe peelout
              do you have a clutch aligning kit ?? if you do then i think thats all you need
              ________
              Herbalaire Vaporizer 2.1
              "2SIIC"
                it comes with the clutch, just not sure how to use it lol
                  you just stick it in the hole, once the clutch and pressure plate are in place it should be apparent to you what to do. I assume that you just leave the alignment tool in place while you tourqe down the pressure plate, at least that is what ill be doing tomarrow when my bolts show up. The swap isnt that hard but i reccomend making sure you have everything before you start so that you dont have to wait on crap like i did. today marks the beggining of the third week my accord has been down for that very reason.
                  spin city
                    ya ill make sure i got everything, plus i got an 85 accord as a beater parts getter so its not a big deal if i dont have everything.
                    What sockets/special tools do i need? I know the drill bit i need, but it says u need a TAP also....for 10x1.25mm, is a tap the "drill bit" that creates a thread for the bolt?
                    thanks guys!
