Please I really need some help!
    I dont no where to begin. My dash and tail lights do not light up, every time i put the smal light fuse in it pops immediately. Also my headlights do not turn off. When I turn the head light switch nothing happens at all, even when the switch is off the headlights are still on. To turn them off i have to take out the lighting relay. Has anyone else suffer the same problem, This seems like a big electrical nightmare to me, please HELP ME!
    ~~~ Never Drive Faster Then Your Guardian Angle Can Fly ~~~
    if your poping fuses that means you have a short. someone probably messed around with some wires and messed something up. later.
    Avoiding dirt at all costs
      x2 on the nightmare man....sounds like some serious shit. Who'd you buy the car from? id take it to them-actually, id get it goin at about 10-15mph, jump out and let it cruise on into their living room then climb through the wreckage, find the guy and kick him in the testicles.
      If the previous owner/dealer wont fix it, you may end up having to go to a dealership/mech and have them figure that shit out. Unless you can like pull the ECU or the main fuse that controls everything
      Originally posted by Jarrett
        Yea i would talk to the prev owner...i agree with TYPE G...sounds like someone fucked something up and its shorting causing the fuse to blow.
          okay.. since the headlight will NOT turn off.. let me think.. if u have a 100watts light blub in that headlights. and u have a system strong with no capacitor.. then ur using alot of juice on the battery (depending on ur battery) causin the headlight wire to burn.. this begin to happen when the light start to dim cuz i had always burn the wires and it was nasty on my first honda accord 91. now i got a honda accord 93. i would say take out that light blub and put a regular 55watts for now. and the wires that hold that light blub u gonna have to check it throughtly. it is damage somewhere makin contact. follow the headlight wires u'll find sumthing funny. as far as the interior and all that . u probably got a wire burn on the parkin lights. it plays a small roll in the interior lights. but to be for real. u gonna have to check all those wires related to lights. i would say check all the wires that's connect custom. like neon lights, l.e.d.s lights. all that stuff. cuz he might've install it ghetto as hell with no tape coverin the wires. ur gonna have to tape em. check under the dash or any explose wires. then try putting a new fuse back in.
          DEFJAM
          MY RIDE ON CB7 DEFJAM on 93
            i just thought of one more thing. u mention u pull out that relay for the headlight.. replace that relay. maybe it's damage keepin the power going in. that really could be it.
            DEFJAM
              its not the really i changed it five times
                Open up a repair manual to the wiring diagram for your car, and start checking the wires. You've got a short somewhere.
                  try to list mods done to your car that may help us narrow down the problem
                    There is a Day Time Running Relay that controls a lot of the cars lights including rear lights. If that is old and the contacts are fried, then it will cause fuses to blow. its located right under the dash to the left of the steering wheel.
                    Check this. I got a new one from the Honda Dealership for 90CAD.
                    maybe this pic helps to locate the relay.
                    DEVOTE
                    FS: Lokuputha's Stuff
