As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
another overheating thread
    I have looked but I can't seem to find a answer to my overheating issue. I did an engine swap a while back and the temp gauge says its overheating. heres the weird part it starts to overheat in 1-2 minutes after starting it from cold. I know it is not the thermostat because I removed it to check to see if the water pump was working, and it does. the hoses both warm up at an equal temp, but the needle is pegged on the cluster, I know it can't be that hot because I can put my hand anywhere on the engine and not be bothered by the temp (ie the exhaust manifold,water necks ) so can anyone point me in the right direction because this is just annoying.
    it might be the thermosat or whateva it's spelled. maybe u got some air in it that need to come out. this is a MUST or u'll fuk up ur waterpump. when u take it off and put it back. u already have air lock inside. u gotta open a pin and take the air out. it's very easy. open it and let the coolant spills out till the coolant flow out of it freely instead of like a wave. if that dont do it i say replace whereever the sensor is.
    DEFJAM
    MY RIDE ON CB7 DEFJAM on 93
      how do you check if you have a faulty waterpump. im overheating as well and haVE CHANGED THE THERMOSTAT BUT DONT KNOW HOW TO CHECK WATER PUMP WITHOUT REMOVING IT.
      "...B*tch got out the car lookin more like Freddy Jackson"
        Dude i looks to me like u have a bad temp sensor they go out its on the termostat housing
        PETRA tow montebello
          Also when a water pump gos bad it starts leaking from the timeing belt first u get a drip then as time goes by it turns into i major pain in the ass with a big ass leak
            Check that first. Ignore the water pump thats pointless to check right now or it would be the last place to look.
