DRL light problem
    DRL light problem
    well i know that its the daytime running lights but the dash light is on all the time except when the beams are on. is it supposed to say that all the time? im a noob and i dont know anythin bout the electrical on the 4 gen. please enlighten me..
    did you install them or are they stock? later.
    Avoiding dirt at all costs
      Even though the dash light is on, are the DRL's themselves on or not?
      1992 Honda Accord Coupe LX
        do you have a burnt high beam bulb?
        Thanks to Ronald for the great picture.
        __________________________________________________ _______________________
        www.vancouveraccords.com
        www.esodraggers.com
          ya check your bulbs, and if they are ok then its probably your DRL relay. just take the circuit board out and re-solder the back side. I did it to my car and its still working.Its kinda like the main realy trick.
            its all stock 91. i dont see any lights on when i walk around the car, unless its in the "on position".. i havent checkd the high beams but i'll do that.
            also my back brake light is out, the one in the back window. is that gona make a difference?
            how easy is it to replace? i looked in the trunk and i could see the wire goin into that area.
              Just twist the connector, buy the same bulb at the store and replace.
                just remove the drl fuse, i have drl on my 2 cb7 and i hate this (Yes im canadian! ) lol . why have light on when its daytime? i also have hacked up 2 9005 to fit in low beam.. it much brighter
                almost stock...
