there is a ground to the thermostat housing??? how is it run???
please help
my car did the same chit. I do suspect that it was the "Igniter" . It is not a mudule or anything else. Its an Igniter. Look it at a parts store. No one sell em i think .
My car died down the road. I took it to the nearest shop and they charged my 220 for a piece of shit piece that woul cost lik 25 bux.
my fuel pump would not come one i think its gonna be one of those things that easy to fx but payin for some one to finding the prob lem is gonna bite ya in the ass
The igniter is the ignition control module. The small part in the distributer that has three wires attached to it. They call it an igniter here but it is an ignition module when you buy it. The only parts inside the distributer is the module, coil and pickup assy,rotor and a top dead center sensor which can not be replaced. If your coil, module and rotor is good,(I doubt the pickup assy would be bad), I would suspect the engine TCU has failed.Originally posted by CB7Junkiethanks, im trying to find a used a distributor. im hoping that this will solve the problem.
If you can get a known good distributer to try I would do that first, then an engine TCU. Could be the main relay failed if you haven't looked at that.
The 90 Accord 4DR Sedan my son and I are building.
thanks alot, ill look into all of that this weekend.
and also, you (rlyons) posted a link on how to run a check at home. and it says that the d4 light flashes for the tcu. well.... i have a mt which means no d4 light. what do i do???Last edited by CB7Junkie; 01-19-2007, 04:57 PM.Sig removed due to excessive size
You don't want the TCU codes you want the ECM codes, the check engine light will flash for them.Originally posted by CB7Junkiethanks alot, ill look into all of that this weekend.
Here they are;Originally posted by 4doorkillerokay. i jumped my ecm and tcm trouble codes like cb7junkie. now where do i go to read them?
http://home.earthlink.net/~michaelpk.../ECM_codes.PDF
http://home.earthlink.net/~michaelpk...TCM_codes1.PDF
Make sure you have a good connection because it should at least light up solid when you jumper the two terminals. Does it come on for the check when you first turn on the key?Originally posted by CB7Junkiewhen i did it the check engin light never came on.
