Wierd brake problem
    Wierd brake problem
    My 91 Wagon has a wierd brake problem. When I am sitting at a stop light the pedal seems to slowly sink lower and lower. It never goes away completely and there is always enough power to stop the car - but it is very strange - almost like a vacuum problem or something. What could this be?
    Your master cylinder is going bad. I have the same problem (and it's been doing it for 3 years... ) The part isn't too expensive, and the work isn't tough at all. Change it out and be sure you bleed your brakes properly. If you have ABS, it will complicate things a bit (someone here can probably help with that... I know nothing about ABS)
      its a common problem, replace the master cylinder and your good to go.
        And give those ABS sensors a good clean while you are at it!
          91 Wagons didnt have ABS...or none that I know of. As mentioned change out the brake master cylinder you should be fine.
            Sorry, didn't know if they did or not.
              refer here:
              http://www.cb7tuner.com/vbb/showthread.php?t=57891
              Gary A.K.A. Carter
              [sig killed by photobucket]
