what can cause the check engine light NOT to come on??? i know that it is supposed to come on for 2 seconds when you turn the ignition on but mine dosent. got ne ideas???
check engine light
well, this may be true but the main reason im asking is bc the car wont start. no fire to the plugs. i have already tried everything: new igniter, coil, cap, rotor, wires and plugs. its not the main relay. so i guess the real question is, what controls the check engine light and does it also control the starting of the car???Sig removed due to excessive size
Bad ECU if you know the bulb is fine. Get another one.
Usually NO CEL is a dud for an ECU. What you can do is find a working car with the same ECU and start your car. IF the other ECU works then your ECU is bad.
