Hey, I was driving today and noticed that when I am in the low-rpm range, my car starts to jerk like it is about to die. Does anyone know what is wrong with it? I havent the slightest clue. Please help me. Thanks
Jerking
is it 5 spd?"This truck is 100% sh*ts and giggles."
"Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
Disregard females, acquire currency
BUS 62 AIN'T F'ING AROUND!
Manual or auto?
Does your idle bounce around in neutral (say from 800-2000rpm)?
Does it completely die if you don't give it gas?
It could be the generic "surging idle" problem along with old motor mounts.- Ghosty
WTB: MAP sensor (2+bar), IAT sensor, ECU & dizzy harness plugs... PM me!
FS: coupe window rain guards, f22a6 intake & ex mani, cams, PT6 ECU, valve cover, dizzy caps, OEM fogs... PM me!
Sounds like the issue I've having, but 10 times worse. I suspect a tiny vacuum leak or EGR issue, but its mostly a guess.
Sorry I can't help anymore, but if I uncover anything, I'll be sure to let you know.
Hopefully someone can set us in the right direction.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
Hows your tune up.
my friend had the exact same problem in her car, i think.. its in low range rpms, and it does it worse when you give it more gas, right? you might wanna check the spark plugs, wires, or distributer. hers were the plugs themselves.R.I.P 90 lx fodo ..my baby!
R.I.P 00 DC2 gsr
R.I.P 92 lx fodo
R.I.P 91 dx fodo
rockin a 2007 ridgeline rtl
Hmm...that does describe mine, except it always clears up at 2,000, and doesn't always do it. Perhaps a lazy EGR valve or starting to clog? All tuneup stuff is semi-recent or checks out OK. Mine's also a 5-speed. I'm gonna keep an eye on it and see if the behavior changes with gas, temps, etc. See if I can find a correlation.Originally posted by accordaffairIs it only in the 1500-2500 range under low throttle?
could be clogged egr ports
I'll be able to check accordaffair's hypotheses when I get my new IM on.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
This is my problem right now and I have done the following with no Luck:
1- New dist cap and rotor
2- New wires
3- New NGK Iridium Plugs
4- New fuel filter.
5- Cleaned out EGR Valve with carb cleaner
Does anyone have any ideas on how to fix this problem?
Agreed.Originally posted by accordaffairYou should clean the service ports, egr valve is not as important.
As a test, why not disable the EGR valve? See if the problem still occurs.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
