Trans/Clutch issues? Help Please!
    Ok what is going on with my car? The clutch engages about an inch off the floor, has a very narrow band where it actually does anything and the rest of the pedal travel is bouncy, loose, and does nothing. Also I have to fight the stick into each gear but it comes out easy enough....WTF is going on here? It's been really cold here lately if that helps. Also the stick has been kinda sloppy once its in gear, jiggles quite a bit even in gear.
    1992 Honda Accord DX
    Coupe 5spd
    2.2 liter I-4 (code: F22a1)
    125hp @5200 rpm 137 lb/ft @4000 rpm
    (\__/)
    (O.o )
    (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
    You ever try checking if you have fluid in your CMC reservoir?
      I know this will sound really dumb and noob-ish (I still haven't purchased a Chilton's manual) but where is it? I took a 30sec peek under the hood before I went to work and didn't see it......I found the PS, Brakes, Wiper fluid, but no Clutch Master Cylinder...
      Coupe 5spd
      (\__/)
      (O.o )
        The master cylinder is on the other side of the firewall from the clutch pedal. They are attached. Directly next to the brake master cylinder on the firewall is the clutch fluid reservoir. It looks like a smaller version of the brake master cylinder reservoir.
        '92 LX.
        JDM H22a.
        My Member's Ride Thread
        Sold to: tysCb7, johnD1079, AccordHybrid92, GUA-D'zCb-7, judonoh, DriftProjectR, AeyJayCB7, C91BLX7, H23CB7
          Clutch Master Resivor is right next to the Brake Master Resevor...it looks like the brake master but the smaller version...u can't miss it...if u can find the shit for the brakes and the clutch master resevor is just right there!
            the other side=the engine side
            '92 LX.
            JDM H22a.
              mine did the same thing add fluid dot 3 brake fluid is wut it takes guarnteed fix.
              cant wait till im all done
                sounds good, so I don't have to replace anythign expensive, is that what I'm getting here? Its in the single digits here so replacing any parts would really suck, but if its just fluids... is there a leak to repaired or does this just happen sometimes?
                Coupe 5spd
                (\__/)
                (O.o )
                  ok so I'm looking and I can't find the reservoir. I feel like such an idiot, I'm off to go buy fluid and a manual, be back in 20min or so, can someone post a picture of give me a deatiled description, I just can't find it for nothing
                  Coupe 5spd
                  (\__/)
                  (O.o )
                    ok so I got the manual, is it the little ugly black bottle on the left side of the engine bay under a black box thing? I have to remove that to fill the reservoir?
                    Coupe 5spd
                    (\__/)
                    (O.o )
                      ok do u see the master cylinder for the brakes look to the right of it and thats the one for the clutch..
                      http://www.get-gifts-for-free.com/?ref_id=4810
                      1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
                          sorry I forgot to come back, we found it about 5:30 (the comp crapped so we figured it out, I read the cap for it the first time and thought it had something to do with the brakes since it talked about brake fluid. I was a little confused at first. But its all good now, but thanks for the help, and if nothing else it motivated me to finally get a Chiltons manual
                          Coupe 5spd
                          (\__/)
                          (O.o )
                            If its low just fill it up and pump the clutch pedal a few times. Take off cap and fill. After a few pumps you should feel pressure come back. It has nothing to do with the brakes both are separate reservoirs as you can see if you look closely.
