Today tryin' to go to my boys' house to chill over there. On the way to the gas station first, filled it up and knew it wouldn't start right away. Waited and tried a couple times to start in between the 20-30 minutes of sitting by the pump. Finally started waited about 3 minutes, took off from the pump, made a U turn under a bridge, and it made a klunk noise and my cb just completely shut off with the oil and battery light on. Pulled over luckily into a parkin' lot at Joe's Crabshack, and waited for another frickin' 20 minutes. This time i did this!...I slightly left the passenger and driver door opened. Where it's NOT shut all the way and the belt thing DOESN'T hug your boobies and the door indicators are on for both. It started after a while, and my car had NO problem of shutting off what-so-ever on the 20 minute drive to my buds house...I know this has to do with somethin' electrical, and plus i got a new battery, new starter, and new thermal valve around the beginning of 05'... new PCV valve, new belts, new oil near the end of 06'. So i JUST need someone here knows what i mean and what im goin' thru and/or to give me any lil info that might help, or even suggestions and advice. Is this an Alternator problem or what else could it be?
