ive heard about ppl cutting the ac belt and gaining some hp. n e one kno how much u gain? im just debatin if its worth takin out
cutting the ac belt?
Cutting your power steering belt wont give any extra power but it frees up some lost power due to the power steering pump running off the motor. Theres no specific measurement on what you would gain from it but if you were to completely remove your power steering and ac systems instead of just cutting the belt you would shed a few pounds off the front end and free up some power from parasitic drag cause by both systems.
You can free up power by either removing the P/S belt, or just installing the Unorthodox Racing pulley set. You have to remember that the A/C only drains power when it is being used, when the A/C compressor is off the pulley is free spinning and has very little drag. I highly recommend just going with the UR pulley set if you want more power, plus the car will rev faster with the lighter pulleys.
-KyleSOHC Non-VTEC F-series for life
"It is the fools prerogative to utter truths that no one else will speak."
-Morpheus (The Sandman)
