As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Power door locks Relay
    Does anyone know where the relay is located for the power locks on my 92 Accord?
    honda life 4218
    Id assume in the door....
    there are some relays under the hood in the fuse box and in the door kick fuse panel...hold on mang.
      naw i know where it's located it's towards the driver wall of the kick panel. IT's not a fuse it's the relay and there are 6 of them together 3 on top and 3 on the bottom i just need to know which one or how can i find out how to test them
      honda life 4218
        the power door lock control unit AKA relay box, is located in the driver door, right above the speaker, its a gray box with two 10mm bolts holding it
          i'm going to tke the door off and check it out tomorrow i'll let u know the outcome thanks.
          honda life 4218
            ok i know i'm like about a week late on this but i have been working mad hours. So here's the new problem i can hit the lock/unlock but when i do, i hear a buzz noise from the door lock control unit. I switched the unit out and still no locks. Do u have any idea what could it be?
            honda life 4218
              I have the same problem, never had time to investigate it though.
                Ethier one or a couple of your door lock switches could be bad. I had that same problem except only it was with my window....
                My Black "H"
                AL Meet!?
                //Secret G2I Lover, Shhhhhhh! //
