F20a ECU on F22b Engine
    Hi
    Here is my quastion
    Can i use F20a DOHC NON VTEC ECU on F22b DOHC NON VTEC?
    What do you think?
    fromhell_3
    It should run, But I would think it wouldnt run to the full potential. The f20a is just a destroked f22b basically.
      so it will run like it is with f22a SOHC ECU ?
      fromhell_3
        the JDM f22B and the F20A are both DOHC motors.
          I am asking this question because I am going to swap for f22b DOHC.
          I can get F20a DOHC ECU easily but I can't find F22b ECU.
          So should I get the F20a DOHC ECU or keep the stock which is f22a SOHC.
          fromhell_3
            If you are not going to be chipping the ECU the H23 ECU will work but you will need to install an H23 knock sensor. If you can get your hands on a JDM F22B ECU that would be best.
            MR Thread
            GhostAccord 2.4L Blog
            by Chappy, on Flickr
              Should I get the F20a DOHC ECU or keep the stock which is f22a SOHC.
              The F20a ECU is DOHC so it will not work on the F22b it is DOHC
              fromhell_3
                Either way, it should run. Getting the proper F22B ECU would be the best option, though. That, or get a chipped ECU with proper tuning. I'm not sure what shipping would be like for you, but there are a few guys on here that would modify a P06 to run the F22B quite well.
