h22 into 92 accord ex and we got the motor in but harmonic balancer is hitting sidewall in bay what can be done???also the tranny mount had to be forced into place and anyone who says they bolt right in is a liar.... thanks for any help you can give
problems with clearance h22a jdm
yeah give us more details on setup - if youre converting from auto to 5spd or if youre attempting to use any of the prelude motor mounts, nothing will line up.
If you are doing auto to 5 speed swap, then you need to redrill the hole on your auto frame rail bracket, or you can buy this mount:
http://www.cb7tuner.com/vbb/showthread.php?t=80212
If you check out my member's ride thread, there is some additional info on what you need to redrill.Last edited by owequitit; 08-06-2007, 04:37 PM.
owequit or whatever i didnt call everyone a liar here i called the people that had told me in the past "it just goes right in" liars because in my experience it hasnt gone right in so thanks for your response MY bracket goes up higher than the others i here f22 a6 rear bracket goes higher up then othersLast edited by slammed4thgen; 08-06-2007, 04:39 PM.
smoke tires, not drugs.
read the sticky in the top of the Swaps forum, i listed out everything "custom"
that needs to be done for a auto-manual swap. and no, its definitely not directly bolt-in, not sure who told you that. never was, never will be
Originally posted by slammed4thgenowequit or whatever i didnt call everyone a liar here i called the people that had told me in the past "it just goes right in" liars because in my experience it hasnt gone right in so thanks for your response MY bracket goes up higher than the others i here f22 a6 rear bracket goes higher up then others
They most likely had never swapped an auto. If you are using a manual tranny car, and and an F22 trans, it is indeed a bolt in affair.
Also, I edited that post after cp[mike] answered it the first time, so it may be more beneficial to you to read it now.
