problems with clearance h22a jdm
    h22 into 92 accord ex and we got the motor in but harmonic balancer is hitting sidewall in bay what can be done???also the tranny mount had to be forced into place and anyone who says they bolt right in is a liar.... thanks for any help you can give
    smoke tires, not drugs.
    Its a tight fight with the crank pulley still on. You have to tilt the engine in order to fit it inside. As for the tranny. That depends on whether you have MT or AT tranny. MT is not a direct swap but rather tapping is involved.
    ...adjust accordingly
      yeah give us more details on setup - if youre converting from auto to 5spd or if youre attempting to use any of the prelude motor mounts, nothing will line up.
        when has any mod that size that didn't come stock "bolt right in."
        everything need to be adjusted and fit into its new place.
        every newb should figure this out,or at least do some research before hand.
        100's of people have made them fit.research. take your time.
        FS: DSM turbo parts,OEM parts, and more.....
        My Members Ride Thread - R.i.P
          i am doing auto to 5 spd and using accord man mounts i know i have to replace rear bracket i did replace mount but didnt get the rear bracket
            oh and smokey i did the research and no one said anything about this hence me asking dont reply with smart answers. thanks to the guys who actually replied with what i needed
              If you are doing auto to 5 speed swap, then you need to redrill the hole on your auto frame rail bracket, or you can buy this mount:
              http://www.cb7tuner.com/vbb/showthread.php?t=80212
              If you check out my member's ride thread, there is some additional info on what you need to redrill.
                owequit or whatever i didnt call everyone a liar here i called the people that had told me in the past "it just goes right in" liars because in my experience it hasnt gone right in so thanks for your response MY bracket goes up higher than the others i here f22 a6 rear bracket goes higher up then others
                  read the sticky in the top of the Swaps forum, i listed out everything "custom"
                  that needs to be done for a auto-manual swap. and no, its definitely not directly bolt-in, not sure who told you that. never was, never will be
                    They most likely had never swapped an auto. If you are using a manual tranny car, and and an F22 trans, it is indeed a bolt in affair.
                    Also, I edited that post after cp[mike] answered it the first time, so it may be more beneficial to you to read it now.
