i need a step by step layout on how to do this scared to attempt this on my car i know about bench bleeding and installationn just need to be sure
installing master cylinder
Originally posted by 4CYLPOWER92I never bench bled mine, just switched it and bled the brakes. It's been working fine for 2 years after changing it.
BTW I hope your only using an OEM Cylinder.
If you really dont wanna go out and get a very very handy hanynes manual, all you have to do is find a way to hold it like holding one of the flanges with a vice grip. filler her up and bleed each outlet. a way to push on the piston is use a Phillips screwdriver or i used a Dowel to push the piston in.Last edited by OnBBS17s; 10-03-2007, 12:38 AM.
